2.5l in '90 leggy?
josh_90_leg
2.5l in '90 leggy?
Post by josh_90_leg »
so i been wanting to do an engine swap in my 90 leggacy 2.2l considering it has almost 220k, would swapping in a 2.5l from a 96 outback be a fun car to drive? would the block handle a turbo (if i went that route), i found one for 500 and it says it has 165 psi. compression in all 4 cylnders. new timing belt and has be resealed, that a good price? any info would help, im a newb when it comes to this stuff
also would the 2.5l bolt right in and would my 5spd trans fit it?
douglas vincent
Post by douglas vincent »
It will work fine, you just need to make sure you transfer over your crank and cam sensors. Bolts right in.
josh_90_leg
Get new ones or swap them from my 2.2l?
if the engine was an automatic does that matter since im putting it in a 5spd? should work just fine?
Check out Jason's thread on his swap
http://bbs.legacycentral.org/viewtopic. ... light=swap
wtdash
swap
Post by wtdash »
Here's another LINK.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
