So, I'm having quite the annoying problem with my blower motor; I can hear it run, the on/off switch works as do all four speeds, but there is no air blowing out. It had been working intermittently, but now seems to work almost never. Also, there is an occasional clicking from a relay under the dash somewhere. What's my course of action to troubleshoot and fix this?
What the hell is wrong with my heater?
1993 Legacy L AWD 5-sp wagon
Similar issue on mine...but mainly no high-speed fan @ Defrost (the fan goes into overdrive @ this and MAX AC setting).
FWIW, If you replace the HVAC controls, the '90-91 (?) had different connectors on the back. I 'think' the '92-94 are the same.
GL,
Td
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
i'll 2nd that resistor issue
remove the glove box then you will be able to access the resistor unit
I have replaced one on my 90 wagon with one from a 93 sedan and it works perfectly
I also have a spare hvac control from a 93 in mint shape
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Subarus and Nissans mount the motors in a weird location that allows objects to fall into the fan and rattle around. Could there be something in there that sounds like a clicking relay and has finally jammed the blades?
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
