JDM & USDM Exhaust Manifold Comparison
Not sure if I posted these, but here are some comparison pics of the JDM exhaust manifold and the stock USDM turbo legacy manifold.
http://main.experiencetherave.com/subar ... stmanifold
You can definitely see that the JDM manifold keeps the individual cylinders separated for much longer. Not sure if that change the exhaust note/sound. The crossover pipe is pretty much the same as the USDM crossover pipe.
Once I get the EGT bung weleded on the up-pipe I'm going to send everything off to get coated by Swaintech. I'll post some pictures when everything gets back.
Aerotech
Post by Aerotech »
Here's the stock SS mani vs the RS-RA mani;
Looks like the same setup you have. :-)
Jerry
I got these exhaust manifolds on yesterday and started the car up. It sounded slightly different from what I remember. But that could just be in my mind. Almost sounded a little more raspier. I spent some time trying to find an exhaust leak, and couldn't find anything.
There is something different in the sound. I can't put my finger on it, but it does sound different than it did before....
Aerotech
Post by Aerotech »
I had the same reaction when I fired mine up... rest of the exhaust was the same, but the car just sounded meaner, especially at full throttle.
I put most of it down to the heads and the 2.5L block... I guess the headers do make a difference.
Jerry
Yeah, the headers are the only difference. The crossover & up-pipe are the same. The runners are separated for a little while longer, but that's it.
Glad I'm not the only one that had the same reaction. :lol:
