I have a 94 legacy wagon with stock ride hieght . Will these wheels fit? I know they will actually fit but wasn't sure of the offset? They don't have tires on them yet . Figured I would put a 195/60 on them as I drive alot of snow and the narrower the better in my opinion. The wheels in question came off a 5x100 vw . What is the center bore on my 94 legacy?
Thanx
16 7.5 ET 35 will they fit?
crust productions.com
www.crustproductions.com
www.tunerautomotive.net
35+ offset is a little low. Hopefully some others with direct experience can comment.
Stock offset is around +55mm. Low, meaning they will rub against the wheel well.
the lower offset means the rims will stick out towards the fender more.
for example. i had stock 55 offset wheels on, swapped to a 42et whick means the wheels stuck out 13 mm further.
yours would be 20mm.
195 is to skinny for a 7.5 rim.
you may have some luck though. but try a 215 tire and get your fenders rolled.
also stock rear struts suck, i believe a wrx wagon rear setup will raise the back end and stiffen you up.
turbonator
