Gas Tank Size?
Gas Tank Size?
I tried searching for this but came up empty for a 1/2 hours time. So any links or answers are appreciated. What is the size of our gas tank? and do the vary through 90-94? I have a 92 ss. The reason i ask is i might be going on a 1400 mile (round trip) road trip and i'm trying to calculate fuel costs.
15.9 for the 91. No idea if they change from year to year but I highly doubt it.
one tank i checked was almost 18mpg. but i was using the garmin nuvi navigation since my speed-o isn't hooked up yet! sounds bad to me since i saw in that vid i posted the car is suppose to get 19 to 25
Jesus Christ, my friend back in high school with a big block '68 Chevelle still got 12.
Thinking of the MPG I'm going to get in this car while paying like $0.30 more per gallon is not comforting to me coming from driving the 1.0 3cylinder metro hatchback.
lol no doubt especially after I put on the TD05 and bigger injectors and standalone.
The Mazda gets 30+ driving fast-normal. Duchess got 25 driving like an asshole (in a manner that I don't think the Mazda would be able to sustain for 50k, never mind 150k), 23 when I went to running the turbo engine as N/A and driving about the same. Going for 30 with the turbo installed and a few aero mods.
I am wondering how the exhaust affects mileage. After taking apart my exhaust it is apparent the exhaust manifold can have leaks after so may year causing the o2 sensor to tell the ecu to run rich.
dammit. i'm starting to question if i want to do my setup now. 3in. DP 440cc injectors and td04. sounds like i will get worse gas mileage
I don't drive very hard, I think it needs some stuff like the 02 sensor done etc, I will look at that stuff soon.Mattheww044 wrote:I wonder whats causing that. Do you drive hard? "Fuel related" maintenance kept up?
Ive done K&N, 02 sensor, fuel pump, fuel filter, etc.. and still get 15-16 reguardless how I drive it seems
Got a new radiator installed a month ago, and it idles a lot better now.
1992 Legacy SS -stock
Think about it as in how many more smiles per mile your new setup will give you.socalwb wrote:dammit. i'm starting to question if i want to do my setup now. 3in. DP 440cc injectors and td04. sounds like i will get worse gas mileage
I test drove an STI a while back and I swear I'd have the biggest grin if I got to take that home every night. Effortless power (to me, an owner of a currently stock SS)
lol... everytime i go out and smoke a cigarette i cant help but to stare at my t-leg, i couldn't imagine if i had an 04 pug nose sti in the driveway!
so is the gas tank size 16 gallons for cars 90-94? i filled up last night and the gas needle was almost on the very last white line and i only filled up 11.35 gallons i believe it was?!?!?!?!?! does that mean my gas gauge is off or can we go past the last white line?
Probably both. You can go past the white line. When I just started driving my dad taught me to not let it go that far because you're letting the tank be filled with dirty air.
Most I've ever filled my subaru was 15.1 gallons.
