revtronix chip not connecting? ::EDIT:: Now running...Kinda
so i installed the chip and i have the cable. i also downloaded the revscan form the revtronix web site. but when i plug it in to the computer and the car it still says disconnected. what am i doing wrong?
::EDIT::turns out i had a bad usb port on my computer. now it is all fine.
I know that the chip has to learn what is going on but my car is not drivable. it wants to act like a anti lag system. i know that the cam timing is correct. the spark advance seems really high...50. it doesnt' like 2nd gear. only 1st. and it seems like when there is ANY load it start popping and then want to die. sounds like a giant piece of shit. is that normal? there are no error codes.
-91ss, 250,000mi rebuilt, tmic, tdo4, agx's w/groundcontrol, f/r strut bars, rust
-83 gl wagon...350,000mi custom dents
-62 honda 55, (moped)
-74 Yamaha rd 350
-74 Yamaha rd 350
windows does see the device
and no it did not work on the stock ecu.
I just rebuilt the engine, i pulled the ecu out of the car and installed the chip before i put the engine back in. i just today tried to connect the cable to the car but it said disconnected in the bottom right. do i need to connect any other wires to get it to connect? right now all i did was plug it into the car, and into the computer
-74 Yamaha rd 350
-74 Yamaha rd 350
haha magic is what i thought too. i took the ecu out again and put the chip in....no connection. car wont run, im pissed haha. ya the icon wont connect it.
-74 Yamaha rd 350
-74 Yamaha rd 350
Did the car run perfectly with the stock components before you upgraded?
What parts did you upgrade that require the chip?
I've found that the chip will expose any flaws in the parts you might have, due to running things closer to the margins. vacuum leaks, boost leaks, crappy flowing injector/fuel rails, etc.
'11 WRX Limited
'94 TW | R.I.P.
this is not what I wanted to hear
Is this the chip level 1 or 2 or the new chip ? I'm wondering because I was going to run the new chip for my ej22t/2.5 sohc build.
you could always try another chip, but im thinking something may not be right with your build. you should put the stock injectors and maf back on anyway until the engine is broken in.
be sure all your pcv lines are correct, vacuum lines ect. ect
