I've got a ton of parts left over from the engine build and the shell swap so heres a list of stuff I dont need anymore...
2003 NA Intake Manifold... Has a newer style throttle body... but isnt fly by wire... Good ol cable throttle. Also has EGR blocked off and an aftermarket FJO MAP sensor installed in the plenum. Comes with Top Feed Fuel Rails and Stainless Steel braided fuel lines. No Wiring.
$150
93 Turbo Automatic Radiator. Came out of my 92. Works great... Not that many miles on it... maybe 15-20k?
$100
93 Legacy Turbo SOHC Cam gears
$20
92 Legacy Turbo Power Steering Pump, 250k miles... Works but needs to be resealed... basically take the resevoir off and reseal it with Fuji Bond. I have the power steering rack if your in dire need of one... but I think it was leaking from the connectors or maybe elsewhere?
$20
98 LGT Intake Manifold... this is in great shape looks brand new. Has the EGR port blocked of and its pretty much bare... Would be great for a DOHC head swap.
$60
93 Legacy Turbo Intake Manifold Dirty... needs a good cleaning... Comes with throttle body... I think it has IAC on it but I'm not totally sure... Has wiring but it needs fixing... I had to steal a few connectors off of it for my wiring needs on my new engine. This also does have Fuel Rails and lines.
$50
The prices dont include shipping and are obo.
I have a quite a few more odds and ends around here if you need somehting just ask.
FS: Parts left from swap and engine build!
Re: FS: Parts left from swap and engine build!
$20
Do you still have these?
$20
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
