http://www.revtronix.com/products/bclegacy1.php
is the "select monitor" the Programable chip that everyone has been waiting for? or is there something else that is in the mix?
revtronix chip programable?
no that is not the chip:
"This USB cable will allow you to use a laptop computer as an engine diagnostic tool for OBD1 Subarus which support the Subaru Select Monitor (SSM1) protocol.
Features:
•Logging of sensor readings and engine parameters
•Reading error codes
•Active control of ECU outputs
Drivers and RevScan logging software (Windows only) are available as free downloads. This cable will also work with any Select Monitor software that can use serial COM ports."
If it was, everyone would have boughten one by now, $50? haha
Features:
