http://denver.craigslist.org/pts/1574773983.html
on my 1992 subaru legacy sedan.
will these fit?
The lug pattern for our cars and most subarus is 5x100 so these should bolt on. Without knowing the offset you can't really be sure if it will clear everything but since it was on a wrx it should clear. 8 1/2 is pretty wide and it may touch the struts when installed, and on tight turns it will probably rub something. I'm running stock wrx 16'' x 6.5'' (don't remember the offset) with 205/50 tires and only have about 8mm between the tire and struts on the rear. From what I've read, when going with that wide of a wheel it's all about offset and then maybe having to roll the fenders. You may want to do some research about negative offset and positive offset before you jump on these, or just buy them and try them and if they rub just sell them.
93'TLegWag171k StockBlock,TD05,HallmanMBC,530cc,Walbro255,shortram,LWpulley,DIS-2,MSDcoil,cxrFMIC,trans cooler/external filter,WRX wheels/brakes,CES w/Borla muffler,QTP elec cutout,REVchip2,KYB GR2,GroupN tops/all fr bushings,STImounts,GSD3 tires,LM-1,etc
