sti tank and pump.. help
justin the subie
ok well i ended up with an '04 sti tank and pump... everything fits and works except the gas gauge.. any ideas??
'92 TW "Hana" ej20tt obd1 <too many to list< sold
bought back
Re: sti tank and pump.. help
You will likely need to swap over the main fuel sender and/or double check the wiring.
justin the subie
the main fuel sender meaning my orignal pump and brackets (pass side)??? or the other unit on driver side?
bought back
Without know how the sti fuel sender is setup, I'm guessing it's similar as the older style. You can remove it from the pump assembly. Here's some pics of the sender (pass) and sub sender (driver).
http://main.experiencetherave.com/subar ... uelsender/
http://main.experiencetherave.com/subar ... uelsender2
justin the subie
nice.. thats all i had to do .. just switch over my original fuel gauge units.. thanks!
bought back
Good deal. Glad it worked.
