Looks interesting, what part of the intake is that? Are those functional holes for hoses in that chrome piece? I'd like to see more, especially the finished product. Looks clean!
It would be attached to the turbo inlet. The holes are functional for IAC and other vacuum ports. I'm thinking about getting a 45* bend and another joiner with the ports on it for my PCV and BPV.
I also have a 2 1/4" 90* coupler that I'm gonna use when I put my VF43 turbo on.
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Sweet, did you buy that metal tube like that or did you weld those on there?
