Any one transmission?
Legacy Konig
Post by Legacy Konig »
I have a '94 N/A FWD Legacy.
Many, many miles.
I have a N/A 2.2 with 50K to swap in whenever I please, however I want to swap in a tranny at the same time.
I cruised BBS-
My question-
Any EJ series trasmission will swap up to any EJ series engine correct?
I'm keeping my car FWD-
What would be the best transmission to purchase, to swap to my N/A 2.2?
Legacy? Impreza? WRX?
Any specific year?
I can virtually swap any EJ transmission right, so which should it be?
My question is not how to, my question is which one?
1994 Legacy L
1990 Legacy LS "decommissioned"
Re: Any one transmission?
Is your trans AT or MT?
Subaru only made FWD transmissions until the mid-late 90's I believe. The AT or MT question will help answer your question on other EJ transmission applicability.
Legacy Konig
MT and nothin' but my man-
I wouldn't have it any other way.
So with that considered, what would be the absolute, top desired manual transmission for this '94 FWD?
1994 Legacy L
97 or so seems to ring in my head as the last year they made FWD transmissions.
All the 90+ FWD MT's should work. As for what's the best one. Couldn't tell you. They are going to be pretty much the same. The newer ones may have a slightly different syncro setup, but I don't recall the 2nd gen legacies having a trans that's remarkably better than the 1st gen.
Legacy Konig
Alright, thank you.
That's more than I knew-
Figured I might as well look into it if I had options.
1994 Legacy L
