******UPDATE AT END******
I'm doing an extensive restoration of Duchess and need a few odd parts, so far, if anyone has them.
-Blue plastic latch for rear cubbyhole door of wagon. Like an idiot, I lost the little piece that broke off and now I can't plastic weld it. In fact, let me know if you have ANY blue interior trim as I might be interested or can trade for some black I have (door panels). **This stupid part is the most important one I need as the rest can be substituted or repaired**.
-driver's side front bumper side bracket. It's the deal that fits on the inside of the bumper with those annoying clips and has a bolt welded on it that helps secure the bumper to the front fender through a hole under the marker light. The bolt broke off on mine, though I can substitute a new bolt if necessary, but if someone has one lying around as close to unrusted as possible, that would be great.
-those little metal braces that attach the bottom sides of the front bumper to the inner body shell. Those and a couple other substitutable BS things are the only parts that are severely rusted. I can replace these with alloy as I am with the other couple parts, but if someone has them, I'll get them.
I'd prefer paying you guys than trying to hunt them down in junk yards since the blue is rare, and one of the parts is a real PITA to remove in typical JY mud and probably won't be nicer than what I have.
WTB: Blue interior pieces
Last edited by evolutionmovement on Mon Jun 07, 2010 4:33 pm, edited 3 times in total.
Re: WTB: Oddments
Re: WTB: Oddments
Anyone have the front bumper brackets that fit in the inside in front of the wheel wells, part # 57790 aa241 (left side)? Forgot I needed the damn thing just before I was going to reassemble the front end.
Also, still need the blue wagon cargo door.
Re: WTB: Bumper side bracket and blue interior pieces
Anyone? I don't want to spend $45 for a new bracket.
This is the bracket I need:
Re: WTB: Blue interior pieces
Have the bracket.
Still want the rear wagon side cargo doors, but will consider anything (I can use some parts to make into welding rod and sheet stock for a factory-look column mount boost gauge housing).
