94 wagon pneumatic questions
FujiFast
Post by FujiFast »
ive just picked up a 94 n/a wagon a.t. and it came with that dammed pneumatic suspension. im looking to get a little more height out of the car so i wanted to change out the struts and shocks. the pneumatic stuff had all been disconnected but im wondering what options do i have as far as shocks and struts. I was thinking the 97 outback stuff might fit?
1994 Legacy Wagon n/a awd, (221,000 miles)
Re: 94 wagon pneumatic questions
Welcome to the BBS.
You should be able to use the mid-late 90's Outback struts & springs to get a little more ground clearance. There's a few people that have done this. You can probably find a few more details by searching.
FujiFast
Post by FujiFast »
Excellent thanks. What if i was looking for say... 1.5 maybe 2 inches of lift?
Honestly, I don't know how much lift is provided with the outback struts & springs. If you want more lift, a cheap option is spring helpers that sit in between the coils. I'm not sure how well that will work. There is a company in Australia that sells lift kits http://www.scorpionsubaru.com/
I think there's a few resellers here in the states.
If using the Outback suspension, I recommend the crossmember spacers that come with to keep your suspension geometry in check.
gijonas
Post by gijonas »
Will you sell me your swaybars?
