NO SPARK
jeffrhomola33
NO SPARK
okay so i have 1991 legacy and have no spark.
what i did was took my motor out to put new cams and clutch in. and now it looks and sounds like everything is working, but no spark at all! so some one knew what to check or what i could be doing wrong. thanx
Re: NO SPARK
I would double check all your connectors to make sure everything was put back together properly.
jeffrhomola33
Re: NO SPARK
is there specific ones that matter?
Re: NO SPARK
I would start at the ones you disconnected to perform the work you just did. If everything worked before you did the clutch & cams, then I would look at all the connectors you removed to get things in. Also look for any wiring looms or harness that may be stretched or pulled wires.
