(SOLD)Complete Turbo Manual Swap(SOLD)
Hi everybody, offered for your perusal is this complete manual swap, taken from a very stock '94 SS with 218,xxx miles. I bought the car wrecked in the front left corner, running and driving. The only issue I noticed related to the transmission was that after sitting for a few weeks, the clutch pedal would stick on the floor the first time it was pressed. Not completely sure, but I assume that it was just a leaking master or slave cylinder. Anyways, I'm including the complete front wiring harness (the rest is available if you want it), cruise control computer, pedals, tranny cross members, speedo cable, drive shaft, rear end (needs axle seals), clutch hydraulics (may need replacing), flywheel, and the clutch which was replaced relatively recently (have the shop invoice). If there's anything you'll need that I didn't mention, you can probably have that too. It's all removed and available for pickup immediately. I'm in the Bellingham area, and am willing to deliver down to Seattle if you're committed to buying it, not really interested in shipping. I'm not on the net super often, so if you're really interested call me (Adam) at (360) 820-5646. Thanks for looking!
scoobylover57
Re: Complete Turbo Manual Swap (WA)
Still available?
-Nick-
91 lsi with ej22t swap. work in progress. Sold.
92 SS 5spd. stock. Sold.
94 TW. 6 spd. V2 sti ra ej20g. 550's. rob tune.
94 SS 5spd. stock
94 SS 5spd. stock
Hmm I'm interested in the tranny alone. If your interested in just selling that let me know.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
