R160 Subaru Clutch LSD with 3.70 gears Diff (ebay)
Pooparu
Post by Pooparu »
I though maybe someone would need this.
http://cgi.ebay.com/ebaymotors/R160-Sub ... ccessories
dscoobydoo
Re: R160 Subaru Clutch LSD with 3.70 gears Diff (ebay)
Post by dscoobydoo »
Great, but you would have to use 06-07 WRX tranny
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
'06/'07 WRX were 3.7 and 1:1 front and centers? I thought the only 3.7 from the post GL era were the early fwd manuals. Sweet. Good to know.
Pooparu
Post by Pooparu »
dscoobydoo wrote:Great, but you would have to use 06-07 WRX tranny
Or you could just swap the LSD into a 4.111 rear end. That would be an easier thing to do then replacing the transmission.
dscoobydoo
true.
Just depends on what you want to do with it.
05 GD-STI
00- GF
n2x4
Post by n2x4 »
Swapping the diff isn't that difficult if you can check the backlash. Pull the retainers from the sides, remove rear diff cover, remove stub shafts and then the ring gear off the Clutch LSD. Then do the same for your stock diff (so you can retain the ratios you need). And bolt it all back together, but with the stock ring gear bolted to the Clutch diff in the stock diff housing.
I'd love to get my hands on one of those, but I think I'll continue hunting junkyards before I drop the money. Good find!
SUBARUEHS Racing
