i have the alldata book for subaru, year modle aand motor
Hot damm that was fun!
------------------------------------------------------------------------------------------------------------------------------- 1999Legacy L postal, RHD
not finding anything that matchs, best guess is could be something from the trans. is this the stock motor? or did it come from a dif car because i'm coming up with the 2.5 and 2.2 for that year, and its not showing a GTB.
ok now i'm huntin all the plugs, one other i foudnthat is a flat 3 plug is on the AC pump, how much room do you have to move the wire around? also what colors are the wires?
boost sensor or TPS? or idle air control solenoid valve.
OK, it's a jap import so that might be why. It's definately a 2.0 twin turbo though. There's quite a lot of slack on the cable and the wires are black, red/yellow, red/white. I'll have another look tomorrow, hopefully now I know roughly what area to look in, I can have a more thorough search. Thanks for your help, I'll let you know how it goes!
Oh, that also looks like a 02 Sensor Plug... i was looking at my 20H stuff in my shed yesterday and my o2 sensor i got with my engine has the female end of the plug you showed.
