1993 legacy turbo code 21 help
hi . my fan is always on as soon as i turn the key one position an wont go off.checked the codes there saying code 21. just changed the water temp sensor an its still happening .what next help
Re: 1993 legacy turbo code 21 help
Try resetting the codes and see what comes back http://legacycentral.org/library/literature/codes.htm
'11 WRX Limited
'94 TW | R.I.P.
hi. thanks. i took the batterie terminals of an left it for a couple of hours an it rest the E C U . fan has stopped coming on straight away an starts much better.
