Background image flicker
Let us know what you think about the site and the forums and give us your suggestions on how to make them better.
HappyFrog
Post by HappyFrog »
Am I the only one going mad with background flickering? It's not as bad at work, not that I read forums while at work of course, at home it is much worse. I use firefox at work and msie at home so it has nothing to do with browsers.
Now being parted out
SiCkSTi04
Re: Background image flicker
Post by SiCkSTi04 »
Could be a loose power or video cable. I've also seen the monitor power cable being plugged into a strip with many other power plugs. Try moving the power cable to a power source of its own.
I think I see what you're talking about but I haven't noticed it before. Now that you brought it up it's bothering me slightly. Hopefully I'll forget about it soon.
HappyFrog
Post by HappyFrog »
I tried a couple of the other screens at work, all of them flickered to a certain degree. All our computers are on a secured power source and all machines are grounded, so I doubt it has anything to do with that.
It is really really bad at home, but the screen isn't grounded so it might have something to do with that. I'm at my laptop right now, it doesn't do it at all.
BSOD2600
Post by BSOD2600 »
Flickering background? Not possible. All the stuff on here is static images/content.
Your screens CRT or LCD? If CRT, make sure the refresh rate is higher than 60hz. LCDs only operate at 60hz so don't bother turning them up.
'11 WRX Limited
'94 TW | R.I.P.
HappyFrog
Post by HappyFrog »
All lcd screens. There is no doubt it is caused by static interference, I was just wondering if I was the only one experiencing it since I seem to be having trouble with it everywhere. I can see why I'm having trouble with my screen at home (no ground, electrical installation from the 60's), but I'm really surprised to be suffering from it at work, since the power grid is 3 years old and secured in order to avoid static (and lightnings and stuff).
gijonas
Post by gijonas »
I see it too.
I had issues with this at work, and it was an issue with the LCD screen and the analog video output/connector. When I switched to the digital output (white connector) the problem went away.
So if your monitor & video card support digital output, try switching.
I'm rocking a brand new Sceptre 27" LCD at 1920x1080P via HDMI from a Radeon 5850 video card. I don't think it's my screen or pc.
What I do think it is, is merely an optical illusion. If I put my face close to the screen I can't see the flicker. It's probably just the pattern is messin with my eyes.
BSOD2600
Post by BSOD2600 »
No idea what the heck ya'll are seeing... but I don't see it on any PC I've used with the forums:
1) nvidia geforce 8600 GT connected to an old ass NEC 19" CRT via VGA.
2) nvidia quadro nvs 290 connected to an HP L1950 and L1940T (LCDs). Tried both VGA and now DVI.
3) girlfriends semi-new HP widescreen laptop.
'11 WRX Limited
'94 TW | R.I.P.
HappyFrog
Post by HappyFrog »
All screens are on digital output. My dual screens at work are the ones showing less flickering, in fact so little that it doesn't bothers me, but at home it is so bad I have to resize the window so that the background isn't visible.
It's not an illusion, it's the pattern of the background that is the problem for the screen. I'm guessing the cheaper the screen, the worse it is. I tried blurring it at little and it went away (the background was ugly as hell after blurring though :-))
I could try playing a little more with it at home, I'm going away for the weekend though.
Yeah after closer examination I can now see a fuzziness in the whole forum. It's like the white and black dots on the TV screen when there's no signal (old school).
HappyFrog
Post by HappyFrog »
Sorry to have brought it up :mrgreen:
