Will the STi control arm bushing work with the SS?
Hey guys, I am pretty sure this is causing some handling issues with my car. I find right now even with 17" the handling is still wadely like just doesn't respond correctly and there are 4 new GR2's on the car keep in mind.
I was looking at this mount and it appears they are sitting at different positions indicating that obviously there is some play or the gel bushings are very soft. So I was going to get the upgrade ones, but I figure for $100 these should do the job unless someone can make me think otherwise?
http://cgi.ebay.ca/SUBARU-STI-TRANSVERS ... 19bd89d718
Re: Will the STi control arm bushing work with the SS?
Yes, they'll work as long as you have the correct ones. I'd ask for the Subaru part # to double check.
Here's the ones I stuck on my Legacy. You can see the part # on the box
http://main.experiencetherave.com/subar ... P_4746.JPG
http://main.experiencetherave.com/subar ... P_4747.JPG
http://main.experiencetherave.com/subar ... P_4748.JPG
Ok, he hasn't replied yet, but I have to make a order on this site and they have the same ones. Should be fine right?
https://www.subarugenuineparts.com/prod ... cts_id=746
I am hoping it makes a noticeable difference.
Yeah, those are the same.
