Random AFR hunting....what can cause this?
macipusy
Post by macipusy »
So lately my 91 SS has been acting up. I will cruise and AFRs will be near 14.7. After 5-15 min of driving, it will start hunting in cruise and idle. It will bounce between 11.5 and 16.5 every few seconds. Usually when I turn off the car and then drive it later, it will be fine again for a short time. Once it starts hunting again, it will not stop till I turn it off. It only hunts in closed loop.
I am running a PP6 with a MAP for deflection as well as 550cc injectors on E85.
It started doing this right after I swapped over the new transmission and clutch...which should have nothing to do with the way the motor is running.
Any suggestions as to why it's hunting?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
gijonas
Re: Random AFR hunting....what can cause this?
Post by gijonas »
Any reason to suspect damage to the o2 sensor or wires from removing the exhaust to do the tranny work?,I have had similar issues before for that reason
macipusy
Post by macipusy »
I was pretty careful with it....but it was removed from the down pipe. I have an extra O2 sensorso I can swap it over and see if it goes away.
Anything else that could cause it?
I already cleaned the MAF, but still hunting.
maciek puszynski
16 WRX | 6mt | fa20
gijonas
Post by gijonas »
First thing I would do is go over any wiring/plugs that were
touched in the tyranny change process.
Isn't is supposed to oscillate between lean and rich in closed-loop?
gijonas
Post by gijonas »
his readings are pretty dramatic,16.5:1 is the point where my car falls on its face lean.
gijonas wrote:his readings are pretty dramatic,16.5:1 is the point where my car falls on its face lean.
During cruise and idle conditions there is very little load on the engine.
gijonas
Post by gijonas »
Oh sorry i forgot about the cruise/idle thing.
First question I have, is this O2 a wideband or narrow band? I didn't see it mentioned, so just want to confirm that.
If it's a narrow band, I wouldn't really worry about it. It's oscilating like it should. If it's a wide band reading, then yeah something may be up.
Other thing to note is that the stoichiometric value for E85 is not the same as gasoline or even E10. This table provides some more details.
http://en.wikipedia.org/wiki/E85_in_sta ... ines#Table
Have you tried resetting your ECU?
macipusy
Post by macipusy »
I am reading the values off my Innovate LC1 Wideband O2.
The problem is, that I have run E85 for a while now (3 months) and this problem is very new....last 2-3 days.
I have reset the ECU multiple times.
Right now I have swapped another O2 for the stock narrowband, reset the ECU and will report later, after I drive it, if it is still hunting.
maciek puszynski
16 WRX | 6mt | fa20
macipusy
Post by macipusy »
Very happy to report back that the issue is gone. Seems like the narrow band O2 was the problem.
maciek puszynski
16 WRX | 6mt | fa20
Are you running both wide band and narrow band O2?
macipusy
Post by macipusy »
Yes, I am running both. The stock narrowband for the ECU in closed loop and the wideband for my eyes only...for tuning purposes hooked up to gauge only.
I will get rid of the narrowband when I go full standalone, but for now just with the PP6 I still need the stock O2.
maciek puszynski
16 WRX | 6mt | fa20
gijonas
Post by gijonas »
Told ya so :mrgreen:
Does your WB have a narrown band simulator?
macipusy
Post by macipusy »
I am not sure about the narrow band simulator.....I will look into that.
maciek puszynski
16 WRX | 6mt | fa20
