Turn signal light help; OBD1 swap into 96 OBS
FlatBlack
Post by FlatBlack »
Hey guys. Just coming over to search for some wiring diagrams.
MY 96 Outback Sport Impreza is running/driving successfully with my OBD1 harness/phase1 EJ22/5MT from my 91 donor Legacy.
Still trying to get the tach to show up on the Legacy dash [I'm assuming I don't have somethign plugged in]
That isn't really important right now.
I have lights, brights, but no turn signal or hazard. I also have no brake lights currently, but we haven't even looked for the wiring yet.
I'm trying to wire in my OBS's Hazard switch to use the stock 96 dash, and I have a FSM for the 96 Impreza. I can't find any good wiring diagrams for the 91. Maybe some of you have a picture of the hazard button connector for me, or a copy of the 91 FSM?
Thanks in advance,
- Mat
78 Datsun 280Z Terbeaux, 91 Legacy L wagon, 96 Impreza Outback Sport Wagon EJ22/5MT OBD1 swap
Re: Turn signal light help; OBD1 swap into 96 OBS
Mat,
Welcome to the BBS.
Pretty sure the tach on the dash gets its rpm input from the rpm signal on the ECU.
Regarding the hazards and turn signals. The wiring goes through the hazard switch, so once it's hooked up, they should work.
You can find wiring diagrams on my server.
http://bbs.legacycentral.org/viewtopic.php?f=12&t=14485
FlatBlack
Post by FlatBlack »
Love it - I've been downloading/perusing those this afternoon. I actually found it after you posted it. So as long as I get a 91 Legacy Hazard switch, it should work? [I misplaced mine >_<]
Most likely, yeah that'll be the case.
