WTB sdn sunroof glass
kleinkid
Post by kleinkid »
I need a good sedan sunroof glass that has a good rubber seal piece on it.
vica153
Re: WTB Legacy SS calipers
Post by vica153 »
lucky day for you
ive got front and rear sets... and rotors too. the fronts are shot, rears work good
kleinkid
Post by kleinkid »
I think vica153(Ken) is pulling calipers for me. Initially I told him I did not need the brackets, but then decided I did need the brackets. The right front bracket may not be available though. What Ken does not have, maybe I can get it from cj91legss. I'll let you know. Thanks. John.
kleinkid
Re: WTB Leg SS calipers(got some), sdn sunroof glass, heat s
Post by kleinkid »
I got the calipers and brackets from vica153, good guy, seller.
Still need sunroof glass with good rubber seal on it.
Also, need turbo heat stack chimney with a bracket.
kleinkid
Post by kleinkid »
Really, really need a sedan sunroof glass with a good rubber seal on it.
wtdash
Post by wtdash »
kleinkid wrote: Also, need turbo heat stack chimney with a bracket.
I've got the chimney. If the bracket attaches to the turbo's top 2 mounting bolts I'm still using that...other wise I may have it.
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
kleinkid
Post by kleinkid »
The bracket does bolt to the top of the turbo. Thanks for the reply though.
wtdash
Post by wtdash »
kleinkid wrote:The bracket does bolt to the top of the turbo. Thanks for the reply though.
I found the correct bracket:
If that's what you need, please make an offer.
Thanks,
Todd
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
kleinkid
Post by kleinkid »
PM'd you. Thanks.
scoobylover57
Re: WTB sdn sunroof glass
Post by scoobylover57 »
I've got a sunroof assembly in Monroe WA. If ur interested, pm me.
-Nick-
91 lsi with ej22t swap. work in progress. Sold.
92 SS 5spd. stock. Sold.
94 TW. 6 spd. V2 sti ra ej20g. 550's. rob tune.
94 SS 5spd. stock
