manual valvebody for 4eat?
anyone know of a manual valve body for a 4eat or a way to convert to that? a friend has one on his th350 in a v8 s10 and its scary fast. it makes the shift detents harder so its easier to shift manually. also gives full lockup in every gear. not sure if one exists, but one of you might know about it?
I love to case.
there is a shift kit you can get......
transgo makes it
http://www.txchange.com/sk.htm#Import
SK® RE4R01A
Nissan RE4R01A, RL4R01A Mazda R4AX-EL, Subaru 4 speed ECAT, Nissan – Infinity – Truck - SUV V8 RE4R03A, Isuzu Diesel JR403
1988up 4 speed with or without lockup
Corrects/Prevents/Reduces:
Planetary burnup; 3rd clutch failure; forward clutch burnup Soft 1-2 shift; 2-3 cutloose; Band burnout and low lube flow causing overheating and total burnup
transgo makes it
SK® RE4R01A
cool, thanks. I heard for some transmissions to install a shift kit you must dissassemble the whole unit, others you can just drop the pan. I think Ill try contacting transgo about the manual valvebody, as far as I know its not much more than a stiffer spring and enlarging a hole somewhere.
I love to case.
