STi lateral links
macipusy
STi lateral links
Post by macipusy »
I was wondering if the 06 STi aluminum lateral links would fit our cars. I am running a 02 WRX rear lateral link right now.
I am not positive if the STi and WRX rear suspension is the same geometry.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Re: STi lateral links
run up to the dealership and compare an 02 lat to an 06 lat. they should be cool enough to atleast let you look at the parts if they're in stock
The rear anti-sway bar mounts may be different.....that's all I can think that would be different....
fatgc8
Post by fatgc8 »
The sti has a wider track and iirc the sti links are a little longer then the wrx's. Your also going to need different endlinks to make it work with your sway bar.
2005 STi (500WHP with "SlowSTi" as the license plate lol (Weekend Warrior)
1991 Legacy ss JDM EJ20G swap with STi goodies (DD)
Isn't the wider track just in the front?
