Can't get strut to knuckle bolts off
So i'm doing my bearing and I'm down to taking the bolts and nuts that connec the rear right knuckle to the strut. I've broke a few tools trying to get them off. What donmost people use to get theses off. Do I need to impact wrench them off, should I just use some liquid wrench and elbow grease. I can get the bolt to spin but I can't breake it free from the nut. Anyones imput would be appreciated
90 2.2 N/A legacy awd wagon with outback struts.
Re: Can't get strut to knuckle bolts off
I've used everything, normally I put a wrench on one side and breaker bar on the other after soaking it in PB Blaster. Tight fit for most impact guns & deep impact sockets.
Worked great thanks!
