Hello all,
I am looking for the specs for ej22t injectors for standalone. I have looked all over without luck.
Thanks Sam
Ej22t injector specs?
Re: Ej22t injector specs?
I did a quick search for: ej22t injectors and found endless results. Since I'm sure you did that as well, what info exactly do you need?
Injector opening time and a voltage correction. Maybe I should try by part or injector number. I don't know what that is either so if anyone knows that feel free to share.
Thanks, Sam
Thanks, Sam
Well, i think I will be using mod'd red tops so the search turns to finding pintle covers.. Anyone have that answer?
Thanks, Sam
Thanks, Sam
