FS: More EJ22T parts.
hotdogpimp
Post by hotdogpimp »
I have a bunch more parts for sale. You will get everything pictured for the price listed above each picture. Just need this stuff gone. Shipping weight is included so that you can calculate. I use UPS ground so no shipping to PO boxes. My zip is 60069. I have not tested these items but they are cheap enough.
Ignigter, coil, two Turbo only timing cover parts+ more $15 8lb
Turbo intake parts with release valve. $15 7lb
2 Flywheels $10 40lb
Complete intake . $35 35lb
3 Alternators. $25 33lb
2 Water Crossover Pipes. $5. 10lb
2 Power Steering Units $10 17lb
Bunch of Pulleys $15 45lb
2 Water Pumps $25 10lb
3 Timing Tensioners $25 8lb
2 Oil Pumps. $25 7lb
SOLDAir intake parts with release valve and sensor $25 10lb
3 Prong Charcoal Canister $10 6lb
SOLDBoost Guage Cluster with MAP $40 5lb
STI Top mount Air-Air Intercooler $25 30lb
SOLDJDM Air-Water Intercooler $30 33lb
Pair Cylinder Heads $30. 55lb
SOLDEngine Cover $10 5lb
SOLDTurbo Timing cover $15 5lb
Re: FS: More EJ22T parts.
That's a damn good deal on those timing covers my friend! If I had a SOHC motor I would buy those.
Turboturd
Post by Turboturd »
Hey I'm interested in all the intake parts from air box all the way to the throttle body, also the charcoal canister and the map sensor assembly. Also would you seperate with the water to air intercooler turbo outlet to intercooler pipe? Would you do $100 shipped?
hotdogpimp
I can sell you:
Pic 2,12,13,14,16 for $110 Plus shipping.
Thanks.
interested, quote to 98580?
OddBallRacing
Post by OddBallRacing »
Air intake with release valve, turbo timing cover, MAP assy (if not already sold,) JDM air-water intercooler all to 45247 plz!
90LegacySTI
Post by 90LegacySTI »
Greetings,
I would like to purchase the items from photo 1 as well as the engine cover from the second to the last photo.
Thanks.
'90 Legacy Wagon
STI drivetrain, T-Leg Engine,
68 Barracuda S Coupe
hotdogpimp
Bumped!
aspitfire
Post by aspitfire »
interested in just the intake elbow from the turbo to the throttle body with valve
maxmurphy
Post by maxmurphy »
I'll purchase the sti intercooler and the legacy intake parts.
