What injectors will fit a 1990 EJ22?
silence2-38554
Well, at 240k, the legacy is throwing a fuel injector code (and runs/idles horribly). I am curious if anyone might know what years / engines I could be looking at to source injectors from that will fit my Legacy? 1990 EJ22 w/ an auto tranny. Thanks!
Re: What injectors will fit a 1990 EJ22?
I've got 4 92 or 93 NA red top injectors I won't ever use. $25 shipped. I don't know how many miles are on them or if they are any good but they look like they're in great condition.
silence2-38554
If you or someone else on the board can confirm that they will match up properly with my EJ22, I will take them for sure! Anyone?
silence2-38554
Okay, it seems like if I use the '92-'94 rails along with the injectors, they will work. Do you by chance have the rails with them? Also, could you possibly measure their resistance? They should measure around 12 ohms between the terminals.
The 92-94 non-turbo injectors have a slightly higher flow rate than the 90-91 non-turbo injectors. I would recommend staying with the 90-91 non-turbo injectors. Also, to note, there is a difference between the manual and auto trans injectors.
