Code 12.
Danny-G
Code 12.
Post by Danny-G »
Got code 12, what is involved in fixing this cause winter is coming and I need my car ready to go.
Danny
BSOD2600
Re: Code 12.
Post by BSOD2600 »
http://legacycentral.org/library/literature/codes.htm = starter.
Either follow the FSM (posted in the stuff you need to know forum) to replace the starter switch... or just replace the whole starter.
'11 WRX Limited
'94 TW | R.I.P.
Re: Code 12.
Is the check engine light on all the time with this code, or did it blip on and then go off?
There's really not anything to the starter code. If the car starts, the starter is probably fine. You may have a wiring issue on the lead coming from the starter to the ECU.
I'd suggest resetting the ECU and see if the code comes back.
Danny-G
Re: Code 12.
Post by Danny-G »
The light was on for about a mile after I pulled the code then the light went out till I played in some puddles then it was on again so I pulled the same code, light went out like normal after start-up and I drove home and haven't driven since then.
Danny
Re: Code 12.
Do you have an AT or MT?
Danny-G
Re: Code 12.
Post by Danny-G »
AT
Danny
Re: Code 12.
The wiring shows that it is routed through the inibitor switch. so there may be an exposed wire going to the inibitor switch or coming from the starter that may be causing the problem....or it could be a loose wire in the starter.
