Clutch woes 02-05 wrx 6 puck clutch installed in 92 ss
JZZ30
Post by JZZ30 »
so its been 3 months since ive swapped out a tranny and a clutch in my 92 ss, and i still cant get the clutch to fully disengage...
so far i have:
replaced the clutch master (was properly bench bleed)
replaced the slave cyl
bypassed the clutch dampener with a straight brake hose from the master to the slave
adjusted the pedal play
extended the slave push rod by an inch... (before with the stock length there was a thumbs gap between the rod and clutch fork with the slave fully pushed back, and with the fork pushed forward before you felt resistance)
still the clutch is not fully disengaging... with the clutch pedal held to the floor in gear the car slowly lurchs forward like an automatic... but slips freely. You let the pedal out and it engages fully no problem.
so this pretty much leaves the fault left for the clutch... but i heard that 02-05 are interchangable with ss.
I know for sure that the clutch fork is slipped into place for the release bearing...
but when i had the clutch out i didnt like how the release bearing had to be pulled straight and squarely about a centimeter before the ring (on the other side of the release bearing) would lock into place and pull the clutch finger/prongs.
maybe on the other side of the release bearing you have to bend something in to make it so it pulls right away?
please guys i need your help.
Re: Clutch woes 02-05 wrx 6 puck clutch installed in 92 ss
There's always going to be a little play on the release bearing and when it snaps into the ring.
Did you use all 02-05 WRX parts, (flywheel, clutch, & pressure plate) or did you mix & match between legacy & WRX?
JZZ30
Post by JZZ30 »
shoot i did mix n match i kept the stock 92 ss flywheel... would that be the issue?
Yeah, I'd say that is most likely the issue.
JZZ30
Post by JZZ30 »
shoot... would i have to swap over the clutch fork to from a 02-05 wrx?
n2x4
Post by n2x4 »
What kind of clutch?
Did you resurface the flywheel when you put the new clutch in? The WRX clutch disk has more surface area than the SS. If you didn't resurface it, you're clutch is probably on the lip of the flywheel that hasn't been touched by a clutch disk before.
Clutch fork should have nothing to do with it.
SUBARUEHS Racing
JZZ30
Post by JZZ30 »
comp clutch 6 puck sprung 02-05 clutch. and no i didnt have it machined... just lightly honed. \
well i swap it out with a wrx clutch and hope to god that fixes it
As mentioned, clutch fork is the same.
Also, I'm assuming you meant to say swap it out with a WRX flywheel....not clutch?
JZZ30
Post by JZZ30 »
yes with a wrx flywheel, paired with a wrx clutch
