What should the abs sensor read?
HappyFrog
Post by HappyFrog »
I changed my right rear abs sensor today, but the abs ecu still complains about it. I didn't drive it, I just started it up after replacing it and after a minute or so it started to blink code 7.
Does anyone know what the sensor should read? Is it just resistance and if so, how much should it read when it is in front of and between teeth?
Now being parted out
Re: What should the abs sensor read?
Well I've got some conflicting info from the FSM, It's telling me "Specified Voltage: 0.8 - 1.3 kohms"
Since obviously voltage isn't measured in ohms, I'm not sure sure what's incorrect, the units or the wording. What I'd suggest is measure the resistance on one of the other sensors that you know is working and good, and compare it to the one that is giving you problems. If the resistance is similar/same, I'd check the wiring and or the tone wheel.
BSOD2600
Post by BSOD2600 »
I'd interpret "0.8 - 1.3 kohms" to mean 800 to 1300 ohms. Since when wasn't resistance measured in ohms btw? http://en.wikipedia.org/wiki/Ohm
'11 WRX Limited
'94 TW | R.I.P.
soundman353
Post by soundman353 »
BSOD2600 wrote:I'd interpret "0.8 - 1.3 kohms" to mean 800 to 1300 ohms. Since when wasn't resistance measured in ohms btw? http://en.wikipedia.org/wiki/Ohm
That is what they drilled into my head in electronics class. +2 on checking the wiring especially clean the connector(s).
That should have read "voltage" not "resistance". Sorry for the confusion.
HappyFrog
Post by HappyFrog »
Odd. I measured on one of the other sensors and it returned nothing. Will try the rest and check my multimeter.
magicmike
Post by magicmike »
you need to drive it!!!!!!! at least 10 feet or so. I battled abs sensors for a while and ended up replacing one that the code never went away.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
