After a quick search, I did not find anything that pertains to the particular charging system issue I had, so I thought I'd post my results. I apologize if this has been previously discussed.
I recently had an issue occur with my '93 wagon that I had not witnessed in any of my prior automobiles. However, after discussing the problem with a friend/co-worker who used to be a Subaru Master Tech, I've since found out that this is not an uncommon occurence. My wife and I were on our way home after work one evening when I discovered all of the common symptoms of charging system failure (dim lights, radio kicking on and off, etc). The one thing that did NOT happen, however, was the typical Brake/Battery lights coming on in the instrument cluster. The issue DID turn out to be an alternator failure, but the lights never came on. I just wanted to make certain that my fellow 1st gen Legacy enthusiasts were made aware of this so nobody ended up stranded without power. The key item to watch is the gauge cluster backlights. Those started becomming noticeably dim sooner than anything else (I live in city, so in rural areas the headlight dimming might be more noticeable).
Alternator issue
Re: Alternator issue
A voltmeter can be very useful in troubleshooting this issue.
'11 WRX Limited
'94 TW | R.I.P.
I have had 3 Legacy's and all of them did the same. That battery light is useless! What I did however find came on to warn me was my abs light, and of course as you mentioned dim lights.
Bender-san
Ah, I have no ABS in my legacy, which would explain why I didn't get that light to come on. As for a volt-meter, I had one back at the shop in my tool box AND at home in my other tool box. However, I had no volt-meter in the car, so I had to wait for confirmation of my hypothesis.
The light will come on if you lose the belt. This I know for fact.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Lunatech
I can confirm!magicmike wrote:The light will come on if you lose the belt. This I know for fact.
Robert,
Rio Red 1990 L sedan 5MT at least 302000 mi. and Spruce Pearl 1996 Wagon 4EAT 245000 mi.
georryan wrote:
Don't knock him for thinking outside of the box. At least he has been creative.
