legacy suspension, some kind of lift wanted help!?
i have a 95 subaru legacy and the back sags a bit i put all new suspension in and it still sags how can i lift it back up or how can i lift the whole car more? whats the best way? i have tryed looking at forester springs, but i dont know how and what year would fit my car? or can i use just forester springs and my struts? if you guys have any idea it would be awesome help!
1995 subaru legacy ls few mods,
Re: legacy suspension, some kind of lift wanted help!?
If your looking to get something huge try http://www.sjrlift.com/ if not you can get '95-'99 outback suspension for a little bit of a lift.
Danny
i would really like to lift the whole car up, but right now i really just want and inch or 2 on the back to level my car out, i have alot of weight in my car in the trunk and it sags, exspecially when there are people in the back, it sags really bad! soo how could i just lift the back an inch or two? or level it out?
You could try putting spring spacers/helpers in. They fit between the spring coils and basically keep the spring from compressing as much. This creates an overall higher spring rate and should raise the rear end slightly and make the ride firmer.
where would i find spring spacers or how would i make one that would work? ive thought of that before just never thought it would work.
The ones I've seen are just urethane pieces that fit between spring coils. You may be able to get them at a local autoparts store or find something online.
