WTB 94 engine Wiring Harness TURBO
Lookin to buy an engine wiring harness off a Turbo 94(91-94 same?)
From ECU to engine is all i need. PM me if u got one thanks!
22T
22T
Re: WTB 94 engine Wiring Harness
Try to be alittle more specific. Do you want a wiring harness for a turbo legacy or an n/a?
Re: WTB 94 engine Wiring Harness TURBO
EDITED, sorry thought i had it on there.
no problem, just helpin out
FYI 91 has different plugs than the 92-94's.
Bumppp 91 or  92-94.
Need it for a 20g project.
How much are you offering? It's quite a bit of work to remove.
we have one at the wrecking yard I work at, but it has 2 injectors that aren't getting a driver signal... Boss want to get it running right before he dicides what to do with it...
							'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
I dunno what to offer honestly.
I have a local seller but he askin 150. Im tryin to get the better deal of course.
good luck on the better deal. i pulled one for no reason and its not fun at all. But what kind or car is it cause the n/a harness is the same to the same pin outs, with the exception of the year of the plugs and then the engine harness can be changed.
							90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
Have injector and sensor harness off 93 EJ22t. This has plugs at the inner fender well next to the battery and extends to the sensors and injectors on engine. Intake manifold has to be removed in order to replace. Not as bad as it sounds , but must not have a heavy hand when disconnecting and reaattaching vacuum lines and intake components.  Will take $50 and you arrange shipping Cheers,J
							The big difference between sex for money and sex for free is that sex for money costs less.
Brendon Francis
I dont know! I dont know why i did it, I dont know why I enjoyed it, and I dont know why i'll do it again.
Bart simpson
						Brendon Francis
Bart simpson
Are you looking for the injector harness and sensors harness  that plugs in at the inner fender well behind the battery and extends to the  engine / via under the intake manifold ? Have one off a 91 0r a 93 / $50 each.
Brendon Francis
Bart simpson
						Brendon Francis
Bart simpson
i have a full 93 ss harness out in a box has a cupple wires that need to be fixed but its all there ecu to engine
