Bellmouth DP wastegate Q's
Tommio RS
Post by Tommio RS »
Hi thar people. I was wondering if any people are running a bellmouth dp with a external waste gate?
I have a full 3 inch tbe with a Cobb DP.
So does anyone know of a external waste gate system that works with a bellmouth DP??
Thanks!
93 Legacy Turbo AT Sliver Stock, Ultra Rotty Body
93 Legacy Turbo MT Silver Rob Tune 550cc Lowered GT28 AWIC 4.11 05 Leg GT rims Mint body
95 Chevy Corvette MT ZR-1 Black X Brace Chipped
94 Legacy Turbo AT Blue Stock SOLD
06 Pontiac G6 AT Green Stock SOLD
Re: Bellmouth DP wastegate Q's
You'll need to wire/weld the internal wastegate shut, and just weld in the external WG. It should work.
martimus919
Post by martimus919 »
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
Not too shabby.
Tommio RS
Post by Tommio RS »
Nice brace!
Asfor welding the WG shut is not a problem. Im going to be running it with a VF39 that has the legendary crack on it. So ill see if i can get the welded up, and at the same time weld the WG shut. No bigg
Asfor up pipes? What brand are people using around here. I know people with 05+ leggy up the ultimate racing ver.
