I used the search but didn't come out with a clear answer.
I have a 1994 Legacy 4wd wagon.
I need to replace the front axles.
-My questions are.-
will GC era impreza/legacy axles fit my 94??
also, Does anyone know the spline count on my stock axles?
-Thank you
Ryan
Compatible axles.
Compatible axles.
Re: Compatible axles.
I believe they should work. Are you looking to replace the front or rear? The fronts should be fine. I know for the rears they swapped to male stub axles at some point and time....but I don't recall when.
Hopefully someone else can fill you in.
I was looking to just do the fronts.. I asked on another forum I'm on and got the response axles from 90-99 should def. fit.
