Blower motor relay help!
Hks_bc5
Post by Hks_bc5 »
Hey all, i'm having a hard time trying to locate the blower motor relay, I've looked through alldata and couldn't anything really just a vague picture so any help would be appreciated. Btw this is a 93 legacy sport turbo
Re: Blower motor relay help!
Welcome to the BBS.
Top left, figure 63-3 is the best picture I can get you at the moment.
http://www.surrealmirage.com/subaru/fil ... tion03.jpg
Hks_bc5
Post by Hks_bc5 »
thanks for the pic im going to look into it and ill let you guys know if im successful
Jessekrs123
Post by Jessekrs123 »
Yes, it is wayyyy up in there way back basically on the driver's side fender. The connector is white, it looks similar to the fuel pump relay which is green. It is a lot easier to get to if you remove the rectangular thing right above the hood latch. It will most likely be on a bracket, I just took mine off the bracket and you can work on it from that rectangular cover.
2015 Subaru BRZ
1993 Subaru Legacy Sedan 5 Speed FWD Green (EG33 swap in progress)
1984 Subaru BRAT Tan
