the metal part in the middle of the bushing on the front of the control arm where it goes into the sub-frame is too wide by quite a bit but all it takes is a few mins with an angle grinder and it slips right in.
so much more caster now, the wheel is quite far forward in the wheel well.
the reason i bought them was so i could get more steering angle with out the wheel hitting the control arm at full lock for drifting.
you can see in the curve of the arm how much more room there is untill the wheel would hit the arm now.
*INTERESTING NOTE*
also when i bought my car in 07 it had a smashed drivers fender from an accident and all the suspension has been replaced by the previous owner.
well fast forward 4 years to now and when i take off the drivers side control arm it had been replaced with a forester one. the control arm its self is the same but the mounting point is a lot different (think ALK) for the added height of the forester so my drivers side has had a shit ton more caster this whole time.
