Power Seat Belts
ScoobyLegacy
Power Seat Belts
Post by ScoobyLegacy »
Something is wrong with the power seat belts they keep clicking when the car is turned off and killing my battery. I was wondering how i can disable them they don't work at all they just Click...
BSOD2600
Re: Power Seat Belts
Post by BSOD2600 »
In the FSM, there is a diagnostic you can run to determine which seatbelt position sensor is not working properly. Otherwise, to disable, just unplug the power connector which is behind the plastic B pillar trim.
'11 WRX Limited
'94 TW | R.I.P.
Does the seatbelt guy flash on the dashboard?
It sounds like there is a short or possibly an issue with a limit switch. I would suggest doing as BSOD suggested and unplug the main connector going to the belts. Then you can use the allen key in the center console to wind the motors to their back position and just clip & unclip the seat belt as needed.
darkcrave
Post by darkcrave »
Simi on the same topic, but where is the sensor that makes it go back and forth. some days it will work when i open the door, sometimes it wont. but it does work fine
Tune
TMIC
Fuel
Taillight
BSOD2600
Post by BSOD2600 »
there are two IIRC, one at each end of the seal belt track. as stated earlier, the FSM contains diagnostic procedures to determine which sensor(s) is bad.
'11 WRX Limited
'94 TW | R.I.P.
Your problem may be a limit switch. Here's a thread with info on diagnostics
http://bbs.legacycentral.org/viewtopic.php?f=10&t=42974
