How do you know a tierod is bad?
Shaggy
Post by Shaggy »
How do u check to see if they are bad. Im in the market for a power steering rack and i was wondering how to tell if my tierods are bad. Im sure it would be a good idea to just get new ones anyways, but i would like to know. Thanks for the help guys.
90 2.2 N/A legacy awd wagon with outback struts.
mesoslow6969
Re: How do you know a tierod is bad?
Post by mesoslow6969 »
if you lift the car off the ground and you shimmy the tire left and right and u see play or feel play in the outer tie rod. usually up and down can possibly mean wheel bearing too.
Anti-Seize is my best friend.
That will show you either inner or outer. If there's any play, look to see which one it is.
Shaggy
Post by Shaggy »
Thank you.
gijonas
Post by gijonas »
BTW outers go alot more often than inners
Shaggy
Post by Shaggy »
Will the inners make a little bit of a clunking noise when u get under there to check them out.
beanis05
Post by beanis05 »
Yes not to much noise but if you have someone else do the shimmy you can find the one that is bad a lot quicker by seeing where the movement is
1990 Subaru Legacy L 89k auto to 5 speed winter daily driver
2004 Subaru WRX 80k
1988 Mazda Rx7 vert > Turbo 2 trans swap
1993 Honda Civic Vx Gutted
Shaggy
Post by Shaggy »
Weel i had someone just kina rock the steering wheel back and forh wothout moving the wheels and it didnt move much but there was a little bit of play and a little knocking noise from the inner tierod. The out tierods seem fine. Also should u beable to grab the inner tierod and twist it at all? Both my brother in laws and mine kinda twist just as far as the outer tierod would let me twist it and the outer tierods seemed pretty squishy but they dont have any play. Are the outers still good.
beanis05
Post by beanis05 »
I don't think it works if you just turnthe ateerig wheel I think you need to move the wheel itself
2004 Subaru WRX 80k
Yes the inner tie rod ends are in a spherical ball which allow them to move around.
Here's a couple pictures
http://www.main.experiencetherave.com/s ... P_8196.JPG
http://www.main.experiencetherave.com/s ... aballjoint
