93 EJ22T Water pump & Timing Belt kit
JRHolt
Post by JRHolt »
I've got a coolant leak which seems to be coming from my water pump (slight stream from under front cover while engine is running). I've tried to source an entire water pump and timing belt kit that includes all my pulleys, tensioner, belt, seals, water pump, gasket. I can only seem to find that kit for the EJ22E n/a motor.
Anyone know of a decently priced kit that is available online for this motor? Are there other EJ sohc motors that use the same parts? This is a high mileage budget build car and I don't want to sink a ton of cash into these parts.
Thanks so much!
03 Forester XS, WRX suspension mods
93 Legacy EJ22T, modded
mesoslow6969
Re: 93 EJ22T Water pump & Timing Belt kit
Post by mesoslow6969 »
Anti-Seize is my best friend.
wtdash
Post by wtdash »
The turbo WP is unique to the '92-94 EJ22T (WRX pump works on the '91, I've read), otherwise the SOHC parts will work.
Since you said 'budget' AND the '93 EJ22 na and turbo are both non-interference, you'd be OK w/an Ebay kit. I've used the ImportExperts on ebay w/out issue.
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
JRHolt
Post by JRHolt »
Awesome,
Thanks so much for the info guys. I will probably checkout an EJ22 na kit on ebay.
Thats great!
JH
