Nico's 93 Legacy Turbo
93legacylsleeper
Re: Nico's 93 Legacy Turbo
Post by 93legacylsleeper »
Id like to see more pics of this car with the Black BBS's Im thinking of doing that exact set-up on my silver legacy. Sweet that you found these in 5x100 so no axel and brake changes necessary...??? Seriously this kind of stuff is what gets me going when it comes to working on my car. Your car is Wicked. Amazing work. Serious Inspiration.
NICO
Post by NICO »
well i just started my winter project for my legacy.
motor needs new valve seals
my sti jdm ra trany non dccd needs shifter forks, subaru use some plastic that does not last.
my new clutch and flywheel
my new track wheels. for tires, i dont know which R compund's to get yet.
soon to come my hsd coilovers,
sublunacy
Post by sublunacy »
Lookin good Nico
Nico your always busy i see! If I have time this week ill give you a call I still haven't even shown you my car.
Did you already pickup the hsd coilovers btw?
Nico, you need a dog-box.
darkcrave
Post by darkcrave »
Sickest build i have ever seen!
93legacylsleeper
^+1 It just keeps getting better and better...
Florin1
Post by Florin1 »
Great job Nico. Mi piace multo.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
NICO
Post by NICO »
^ lol Grazie tanto. thanks guys for all the complements.
so just a update, i was changing valve seals on my ej20k heads and i checked the valve guides and they need replacing also. what i have planed for them, is a full rebuild stock specs with some kelford high lift cams.
the STI 6mt is getting new selecter forks from subaru, aftermarket is priced insane for how easy it is to open and work on a 6mt.
the new heads i am useing are ej20k sti spec, these heads oem come with sodium filled valves, shim under bucket with little stiffer spring.
well my new suspension has arrived, there priced right and they use a inverted strut which i love. i am going to get corner balanced and aliment when i put them in, it should be good for the track/street car.
Florin1
Post by Florin1 »
Nice, even have camber adj. on the rear too...
NICO
Post by NICO »
Florin1 i was think the same thing after i opened the box up.
NICO
Post by NICO »
well my new sti shift forks came in to repair my old jdm sti spec c 6mt tranny, the only thing is there aluminum. geuss will just see how long they last.
my motor is ready to go back in, had to swap heads, the ej20k heads under the motor are getting new valve guides with some extra exrta stuff soon to come. motor has ej20k STi heads, stronger springs, special valves, new valve seals.
Ohh...you have some Xtra-S gear fluid there too :)
NICO
Post by NICO »
^ o ya that's my second one, I only use that oil in my tranny.
Well hsd coil overs are done and my motor is working perfect with new heads. Clutch feels great little tuff but good, car runs perfect and ready for corner balance and alignment.
My Jdm mirrors are on also
Falken-18c
Post by Falken-18c »
your car is a work of art exelent job
darkcrave
Post by darkcrave »
selling them old wheels?
[quote="NICO"]well i finally found a set of 2004 BBS rims, 17x7.5 5x100 et53 forged. i started paintting them rim on the left is ready to piant and right side rim is done.
tires i have 215/45/17 P Zero Nero's. i might go down in size becuse under hard corners i get a little rubbing on the rear wheel well's.
[/quote]
Beautiful car! New coilovers always look so damn good. They look very similar to my Tein Type HT coilovers actually and mine also rear camber plates which is a must in my opinion unless you have adjustable lateral links. I just finally read up on how to adjust the dampers on mine. Didn't want to mess with them until I knew how they worked. Turned them from all the way soft to right in the middle which is where the manual says to start with and wow what a difference that made! I was really getting tired of the amount of oscillating that they had. It was annoying as hell. Felt like there were no dampers! Hit a bump and it bounced way too many times. Now it feels much more solid.
Wish my car was as clean as yours and had some of the parts you have like a 6MT. :)
Falken-18c
i wanna go to hamilton and steal this car lol so where is it located lol jk
batlegacy
Post by batlegacy »
Wats your recipe for the 380 whp your running? If you dont mind divulging your secrets?
P.S. that is the most beautiful SS ive seen to date, keep up the good work!!!
NICO
Post by NICO »
batlegacy wrote:Wats your recipe for the 380 whp your running? If you dont mind divulging your secrets?
its a ej22t block wiseco pistons, carillo rods, acl bearings, heads are ej20k sti stock. aps sr56 turbo, aps 725 fmic and 3.5 ex, 4 2 1 headers. 850cc injectors should go bigger i was told, water meth kit, autronic ecu.
soon ill have more power more boost and another franz tune coming. franz also told me if i put one of those rotated 30r turbos i would hit 450 to 500 no problem. but i dont want to swap everything just yet, we are going to see what i can do with what i got for now.
i just add this billet throttle body new style on old school in take, 70mm one. ps it works better on the ej20k intake manifold after my buddy did the mod on his new style intake manifold when porting. it might even work better for the ej20g intake but i dont have one to port.
cant wait for more boost and a new tune more egressive tune.
NICO
Post by NICO »
got my summer bbs rims on with the 225 45 17 dunlop tires for the track, add some more camber rear is 1.6 front 2.3 and had to raise the car up and check corner balance again just to make sure its all ready.
NICO
Post by NICO »
Coming Soon......... GT3076R rotated turbo for some street monster power !!
Falken-18c
AWSOME
Falken-18c
Are u going to the meet in augest 28th
comets
Post by comets »
Hi, awesome job! True inspiration!
I am in Canada, Ontario as well (GTA).
Falken and Nico, that's so cool that you guys are local!
