Is 2wd Automatic and AWD automatic same on 90 legacy?
atvtrailrider
Post by atvtrailrider »
I have a 1990 legacy AWD and the automatic transmission is out? Can I swap in one from a 2wd model. I found one much cheaper than the AWD version. Someone said they are the same except the 2wd one has something over the cover for the AWD.
Thank You
90 Subaru Legacy n/a AWD - Rally Cross Car
86 Toyota Pickup - Rock Crawler
2005 Subaru Baja - Wifes Car
1997 Tahoe - Fishing and Exploring Rig
1990 F250 Diesel - Tow Rig
Re: Is 2wd Automatic and AWD automatic same on 90 legacy?
As I mentioned I think on one of the other forums, the simple answer is no, you can't swap things without a lot of work.
atvtrailrider
cool, I will just find a AWD tranny then. The guy with the 2wd tranny evidently had no idea what he was talking about. He tried telling me there was an inspection cover on the 2wd where I guess would be similar to a transfercase and that you could just remove the inspection cover and swap the rest over and bolt it in.
He was wrong.
Here's some blow up pics of the two transmissions. You can see the driven shaft is hollow and then goes to the center diff, and then the pinion shaft goes through the driven shaft to the diff.
FWD
http://www.main.experiencetherave.com/s ... iption.jpg
AWD
http://www.main.experiencetherave.com/s ... n_assy.jpg
http://www.main.experiencetherave.com/s ... ension.jpg
atvtrailrider
yea you can even see with those pics that the case is different.
