Running rich
irishsetter
Running rich
I am running really rich on my ej22t. I have a lot of engine check light issues and can't seem to figure it out. I think most of the problem revolves around a bad knock sensor but I am not sure how to see if it is bad. I plan on just trying a regular tune up like plugs wires filters and all that but right now I can smell residual fuel in the oil and that ain't good. If anybody has any input on any of this please help. Anything from good plugs and wires to why I have six or seven different engine check signals.
irishsetter
rallysam
Purge control solenoid valve is the last one.
24 and 35 are probably just nuisance codes. I guess I would start with your current game plan: check the knock sensor and give it a tune up.
'00 Impr RS - sold
irishsetter
irishsetter
irishsetter
Scratch that I ran for about a day and the check engine comes on and then it clears. I went to check the codes and got all the same ones. The very first code that comes out is 12 but it only comes out one time when I first start to read them. I am getting frustated here. I noticed that the light usaully comes on when I am in fourth or fifth gear cruising down the road. Does the check engine reset on its own after a time out and no bad signals?
Re: Running rich
hello.
if my car is running very rich, which i think it does, can the rich-condition steal a lot of horsepower?
1992 wagon ej20g
Re: Running rich
Yes!keelhaul wrote:hello.
Re: Running rich
thanks. because i can floor my pedal in fifth gear, crusing at 70mph, and my boost hits 1 bar at once, but my car is hardly going faster :p
1992 wagon ej20g
Re: Running rich
What is your engine rpm while cruising at 70mph? You most likely need to shift down to a lower gear. If the engine rpm is too low, even though boost builds, the engine will lug and not accelerate like you want it to. Shifting to a lower gear is usually the solution.
Re: Running rich
I know it's a late reply, but yeah if you're at 2500 rpm, you should look at downshifting.
