So after I pulled my intake tube off and put it back on, the tube that is attached to the PCV broke off. My question is, what is that tube connected to at the bottom? It looks like its connected to manifold of some sorts. And is it important for me to connect it back up?
PCV valve
Re: PCV valve
I broke that too when I first got my car. It is actually important. Going to need to go to the dealer and order all the parts (hoses, f pipe, etc so 1,2,3,4. ).
http://i321.photobucket.com/albums/nn39 ... 2t_pcv.gif
Re: PCV valve
It's connected to the block. There's a port on the top of the block. You can see it in this picture.
http://www.main.experiencetherave.com/s ... G_2550.JPG
Re: PCV valve
not to thread highjack but where would a catch can go. between 12 and 16 or 5 and 16
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Re: PCV valve
Your biggest source of oil vapor is going to be from the crankcase, so you'd want something after 4, and before 3 & 5.
