how do i adjust throttle stop
legacy 91 AWD
Apparently there were two different throttle stop screw systems used. My 1993 just has a philips head screw. The head faces down and towards the front of the car. Subiekid can comment on his 1992 which has some more complex setup apparently.
Ordinarily you shouldn't need to adjust the throttle stop screw. Why do you think you need to? Our cars have computer-controlled idle; the idle air control valve (below the PCV valve) is a solenoid valve that lets air bypass the throttle body. In fact, if you make a small adjustment to the throttle stop screw and then let the car idle for a little bit, the ECU will learn around the change and your idle will return to how it was before.
It sound like the shop you used doesnt know what the heck they are doing, and now you are confused on how an automatic works. When you stop drive is not disengauged. This problem has nothing to do with the throttle stop or TPS. You could hold wide open throttle and still stop the car while in drive.
Your torque converter is most likely getting locked up. Does your engine rpm drop or the engine stalls when you try to stop.
the lock on the torque converter is not unlocking theres no fault code they put a new speed sensor on and a new tps the g/box was trashed whn i got the car all worn out i am wondering if that was the problem i priced a new tcu up it $1000 cnd, they transmission place said they rebuild is i can wire a swith in to lockup solinod to stop it lock up but theres something else amiss any ideas
for future reference
http://www.main.experiencetherave.com:8 ... sting1.jpg
http://www.main.experiencetherave.com:8 ... sting2.jpg
http://www.main.experiencetherave.com:8 ... sting3.jpg
Hey Admin -
http://www.main.experiencetherave.com:8 ... FSM_Scans/
Are those FSM scans general? What years/models of Legacy are covered by those scans? More specifically... can I use these scans to work on my '94 Legacy, or are they incorrect in certain areas?
-Chris
91SS 4EAT stock, 200k mi
I think most of Josh's scans are from his 1990 manual. Most of it is still applicable to your 1994 but not all of it. If in doubt, ask others on this forum when you have a specific project. :)
OK, at least its for the same car model, just the wrong year. I can make use of it still... Thanks! FSM's are tough to come by, at least they always have been for me.
-Chris
yeah most are from my 90 FSM's. There may be some from the 92-94 manuals.
Here's the root of the manuals
http://www.main.experiencetherave.com:8 ... ual_scans/
some chilton scans.
some chilton scans.
Put the car in the number two selector on a day that it has this problem and drive around. I bet it doesnt happen. The TC should only lock in third and fourth. What happens is that you drive around for a while, the TC locks then when you are coming to a stop it downshifts until in first. The TC "clutches" are strong enough to stall the engine before disengauging when they are stuck.
As for a troubleshooting tool and temporary fix you should disconnect the lead for TC lockup control and drive around. See if it still happens. Highway MPG will be reduced of course.
Another thing it could be is your iac valve is stuck closed, this same thing happened to me, it'd die coming to a stop, did it for days. Then I changed the iac valve it hasn't done this since. I say check that as well, even if it isn't the problem it cant hurt to take a look at it.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
