FS WA parting out 91 SS
The engine and trans are gone, front is bent up, was a 5MT car.
Here's whats left:
Wiring harness
doors are pretty good (red)
trunk is pretty good with nice turbo garnish and no spoiler (red)
hood is present with the right front corner with a small dent (red)
grey 5mt console piece
taillights
headlights (foggy)
front corner lights
grille
other misc parts
Here's whats left:
Wiring harness
taillights
headlights (foggy)
front corner lights
grille
other misc parts
Re: FS WA parting out 91 SS
Hey how much you want for the harness and what kind of shape is it in
92 T- leg Tdo4/top mount,3" inch exhaust ,5 speed 2.5 rs trans, sti seats Wrx rear seats kartboy short throw shifter,Kyb gr2 struts
08 Spec b Legacy
08 Spec b Legacy
the harness is in good shape, some wires by the back of the engine are brittle (knock sensor, etc.) as is typical for these cars but easily fixed.
Any chance the charcoal/evap canister stayed with the car when you sold the engine? I could really use it. Thanks
*Found a canister*
Also, what color is the grille?
*Found a canister*
This may sound strange, but does it have the power antenna in the trunk still? and if so, does it work or did it work?
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
we're having a weather event here, as soon as I can see the car I'll check on this stuff-thanks
Plz tell me its the fancy white color, would love to get a white driver side door and driver side fender if so. Am stuck with my car so might as well fix it. Thanks much in advance
I did have a couple pearl white 91's, one was a stage rally car so I ended up using most of the body panels off the other car
The only panel I still have is the trunk lid. Those parts are hard to find, especially if you need the front bumper.
Good luck with your search.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Thanks for the response, yea thats what im finding out almost impossible to locate one. Gl with the partout
I got one of those pearl front bumpers. I got it as a spare in case i do something to my current bumper, loltoomuch wrote:I did have a couple pearl white 91's, one was a stage rally car so I ended up using most of the body panels off the other carThe only panel I still have is the trunk lid. Those parts are hard to find, especially if you need the front bumper.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
How much do you want for the console? Ship to 86406?
lucas wrote:There were multiple Legacys with 300k+ miles. Jesus will return on a Turbo Lego.
do you need the whole console or just the top portion?
Drivers side hub/knuckle combo in good shape?
94 Legacy Touring Wagon
83 GL Wagon "Mountain Goat" - Sold
I'm rockin' an auto right now and plan on swapping, will the top swap out alone? Also, do you still have the clutch and brake pedal assy?toomuch wrote:do you need the whole console or just the top portion?
ecu available
Interested in thr trunk garnish if its in good shape and your willing to sell it sepately.
Do you still have the R VLSD? How much if so...what about a Passenger side mirror assembly
Yes, I think the top will swap. I think I do have the pedals too...
Omega79 wrote:I'm rockin' an auto right now and plan on swapping, will the top swap out alone? Also, do you still have the clutch and brake pedal assy?toomuch wrote:do you need the whole console or just the top portion?
If I do its from an auto trans SS
mmmkyle wrote:ecu available
I have a 91 trunk garnish, I think it's very good would need to inspect, I could sell it seperately.
feening wrote:Interested in thr trunk garnish if its in good shape and your willing to sell it sepately.
Yes, I have a VLSD, not sure if it's from a auto or 5mt if it matters. I should have a mirror to I can check.
batlegacy wrote:Do you still have the R VLSD? How much if so...what about a Passenger side mirror assembly
what color is the grille? condition?
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Grille is silver, average condition
I'm in need of both front fenders if you have and they are in good shape
91 legacy- lifted turbo Frankenstein
87 244 - drift build in process - ex dd
82 starlet- 4agte
78 510 - dd
82 starlet- 4agte
78 510 - dd
Is the rear sway bar setup still available? I am looking for one to put in my "new" wagon. And where exactly are you located?
Don't know how much of a difference handling wise this is going to do over not having a RSB as it was a pain in the arse to swap the rear lateral links on my other wagon in order to put a sway bar on it...lol.
Brent
'92 Legacy Wagon Winestone, 265K on body, ~100K on engine, 5spd, kyb gr2's w/ whiteline ground control springs, sti top hats, hatch spoiler to be added soon...
