Broken tranny.. so now what?
scootledoo
Post by scootledoo »
so due to the lack of a shop or tools i decided to take my 91 ss to the "subaru guru" where i live and he just gave me a quick diagnosis of main shaft sounds shot. clutch engaged the car starts fine and sounds fine. dis engaged in N and it sounds like a marble in a tin can... :( . it still limps in all its gears "only moved it a few feet. but still makes the nasty sound. but reverse sounds fine? anyways i looked into klienkids "spelt correctly?" thread and im Very interested in the 6mt swap. but it seems everyones given up on posting on it for a final build and or cost. i found a 06 6mt for around $3,000 with 60k "good deal"? and or does anyone know of a rebuild kit for our tannys? or another route i can go with this? any help would be great. thanks
-Scotty
91 Legacy turbo SS
de-snorked,exedy clutch, act flywheel.
darkcrave
Re: Broken tranny.. so now what?
Post by darkcrave »
3,000$ is a good price, come with diff and drive shaft and all that good stuff?
Tune
TMIC
Fuel
Taillight
scootledoo
it only mentioned the tranny but i would kind of figure it would come with it all. ill look more into that.
-Scotty
91 Legacy turbo SS
here's what im currently working on because i have the exact same issue.
A Buddy of mine led me onto finding a WRX Transmission case and putting 99+ 2.5RS guts into the WRX Case. You'll have to get a 4.11 diff.. This is so i can still utilize the Pull Style Clutch setup i have for a wrx.
He has done this in his Touring wagon, and i plan on going the same route.
I have 2 turbo 5 speeds in my shed both with bad imput shafts.. There are a few shafts on the east coast, but they are EXTREMELY expensive
scootledoo
Sounds like a good alternative to me. How well do you think that set up will hold up?
-Scotty
91 Legacy turbo SS
he says he's pretty hard on his setup, and it's still holding up.
scootledoo
Ok ill definitely will keep that in mind. But what of the main shafts over on the east coast. How expensive are they.. im kinda interested.
-Scotty
91 Legacy turbo SS
My 97 Impreza is pretty noisy and it's probably the main shaft as well. Just not sure if it's the bearings or gears. I'm leaning towards bearings. It's been that way for a couple years. I'm just going to keep driving it until it dies :)
scootledoo
Yea my tranny made alot of noise in first sence ive owned it. But never has a warning for when it broke. I got the tranny out finally and im gettig estimates for the rebuild. Ill keep you guys posted on prices.
-Scotty
91 Legacy turbo SS
fishbone79
Post by fishbone79 »
The trans currently in my car (quick swap in of a new main shaft) makes the exact same noises in neutral. However, i know those bearings are all good, but another trans I pulled apart making those noises has a bad bearing on the 1-2 gear on the layshaft. That's the problem in my current transmission as well - but you can put a gazillion miles on it before it will grenade on you (25 k and going, but the noise is getting worse). First gear always spins, no matter what gear you are in or if the car is in N with the clutch engaged... You can demonstrate this to yourself if you've ever had a 5MT open.
Cheers,
morgan
1992 Legacy BF
scootledoo
new up date. got the transmission fixed at a transmission shop in spokane,wa on glass and market. Mayfield transmissions. a guy named shane did it in a week. my real problem was second gear. ill post pics if i can figure it out. "2nd was BAD!!! lol" anyways. new mainshaft, 2nd gear &sync, and full inspection cost me $500.00 through him. number to the shop is 1509-484-9433 if yall are interested. thanks for all the advice and help
-Scotty
91 Legacy turbo SS
